Wireless Thermostats
22 Nov 2008
Essex
I have a Baxi 28HE combi & want to connect a "Horstman" Wireless thermostat receiver to it. The instructions on the boiler a clear "Remove the bridge from position 1&2 on boiler terminal block. However, the receiver has a bridging wire between two "L" positions. It also has a label with SL (off) & SL (on) positions. The instructions state that, if I want to convert it to a"No Volts" receiver, I should remove the bridging wire.
I need to know what to do & which positions I should connect the boiler wires to.
BillW333
Remove the link between L and SL on the receiver. Connect SL and common to the PCB connector block after removing the link.
