I am fitting a light to a newly wired room. Here's my dilemma...
The light will be worked from a two way switch. One switch positioned by the door and one switch poitioned by the bed.
At the ceiling there are:
Four cables. Each cable is 2 core (Brown/Blue) + Earth.
At both switches (door and bed) there are:
Two cables 3 core (Brown/Grey/Black) + Earth.
Plus, there is a 2 core cable (Brown/Blue) + Earth.
I'm ok with the usual three cable set up to a light fitting and two cable set up to a switch but this has baffled me, I've never seen so many cables - can anyone help?
ps. I can identify the link between switches to find the live switch from my loft. I can also see the Supply in and the Supply to the next light fitting set up. But then there seems to be an additional cable which I can't trace. Is there anything else that might help someone understand this?
Thanks for your time. Hope you can help.
