Wirework Shelves?
10 Feb 2014
Staffordshire
Ive seen lots of wirework shelving units but i have something 'sort of' along those lines. Can you buy just a wirework shelf that could be used in my existing unit to replace old mdf shelves?. Dont need the weight or wood or mdf but similarly dont need a metal self contained. Unit. Anything about 300 deep by about a metre that i can buy some of?.. As url link here sort of idea?https://cdn.shopify.com/s/files/1/0...4-shelf-28025547063383_2000x.jpg?v=1665708066
Is it supported all around? As anything spanning a metre needs to be pretty robust or it'll sag like anything.
We don't know what your existing units are?
You can buy pre-made wirework shelves in standard kitchen unit sizes, e.g. to fit units 300, 400, 500and 600mm wide x circa 500mm deep. Try kitchen component suppliers such as Isaac Lord in High Wycombe or TKC in Manchester. Wider than 600mm you can get - it is commonly used in commercial kitchens - but it can't be cut to length and it comes in whatever sizes the supplier dictates. Try any local catering equipment supplier. Any good steel fabricator who deals with stainless steel should also be able to fabricate to order
Sorry for the delay. I was away and finally decided to go with white particle board shelving. Whats the best place price wise online to get some ordered
If you are in Manchester or Sheffield I'd recommend HPP. Ask for cut to size prw-banded 18mm MFC (comes in varioua widths, 2440mm long). You will doubtless have someone local doing a similar service. Forget about doing it on line unless you are absolutely made of money - the shippimg costs are often more than the cost of the material and cutting, and MFC doesn't take kindly to being thrown about in a courier's van
If you have a Selco near you I can say with confidence that you can actually easily remove the stickers from their MFC unlike many other suppliers.
