- Joined
- 15 May 2013
- Messages
- 7
- Reaction score
- 0
- Country
Ok some HELP required on wiring a 2 gang 2 way light switch please.
I have read the other threads but they make no sense to me.
I have the following setup:
A single light switch at the top of the stairs ( Landing) that just operates that light.
A double light switch at the bottom of the stairs that operates both the upstairs ( Landing) light & the downstairs hall light (Main Hallway).
A double light switch by the street door that operates the the downstairs light ( Main Hallway) & the front HallWay ( By the street door).
I have already successfully installed the double switch by the street door ( Without too much hassle).
It is the switch at the bottom of the stairs that I am having problems with.
No matter how I seem to wire it, it is wrong, I have managed to get the upstairs ( Landing ) light to come on / off without problems, & even got the downstairs hallway to work & switch on & off, but then I can't get to switch on or off from the switch by the street door.
The wiring to the switch I am having problems with contains the following wires that appear to be in two separate sections:
As you look at it:
Right Hand side:
1x Blue Wire.
1x Red Wire.
1x Yellow Wire ( With A Red Sleeve).
Left Hand Side:
1x Blue Wire & 1x Black Wire ( Both With Red Sleeves) These Wires Are Twisted Together.
2 x Red Wires Twisted Together.
1 x Yellow Wire.
I might add at this point these is also an earth wire but this is connected to the back box so that is fine.
The switch I am trying to fit is a brass plate with 2 separate blocks on the reverse.
Both blocks contain the following screw holes in a three hole arrangement:
At the top it reads " L ".
Bottom Reads " L1 " & " L2 ".
So my question is this - Where & how I fix each wire ???????????
As you look at it:
Right Hand side:
1x Blue Wire.
1x Red Wire.
Left Hand Side:
1 x Yellow Wire.
