Good evening everyone,
So I am wiring a Turbo Tube Pro 100 4 Inch Inline Fan with Timer. I need some guidance on how to connect some of the wires. The extractor fan should turn on as the switch is pulled to switch a light on, and after the light is turned off fan should run for a set amount of time and switch itself off. I have made a wiring diagram I would be grateful if someone could go through it and help me out with this.
This is the wiring diagram I made:
Can someone guide me on how to connect the remaining wires correctly, I would appreciate a visual sketch or diagram if possible? Also, what would be the best method to connect them as there is no light rose in the light? Should I use WAGO connectors? Thanks for the help.
