Wiring a CCTV camera in the loft
Status
Not open for further replies.
8 May 2012
Cheshire
Due to a neighbor being recently burgled I’d like to erect a Nest security camera just under the eaves. The only power source I can use is the upstairs lighting circuit which currently only uses about 350W (LED’s upstairs). Could / should I spur a socket off this circuit to power the camera? (5V, 1.4A)
Winston is wrong ( and will react badly to being told so ).
5 amp sockets for lighting are very common ( but should only be connected to lighting circuits or other circuits with 6 amp ( or lower ) fuse or MCB )
https://www.tlc-direct.co.uk/Products/CB7047.html
Winston gets worried that a 13 amp socket on a lighting circuit might be used for a powerful appliance or lamp that trips the 6 amp lighting circuit fuse or MCB
We could stop calling them lighting circuits.
It may already have a fan, a boiler and/or other things connected to it.
Having a camera just under the eaves will only catch the top of peoples head, it has to be much lower. Drill through the wall from the bedroom and plug it in.
Andy
Next door neighbour-but-two is a well-respected electrician and he put a camera on the soffit/eave overhang. Given the little power consumption he also spurred from the upstairs lighting with the switch marked with maximum load. I've seen the footage and it captures the face of anybody entering his driveway.
I'm only a DIY'er (hence being on this site) but I did question him about the way he did the work as I was interested myself. He said there is nothing wrong with doing it the above way and that it does not break and regulations.
I have a dedicated circuit to the loft in 1.5mm² T&E from a 6A MCB to two sockets for boiler and cctv camera.
Would it be alright for me to connect some lights to this circuit?
More than that - it is specifically stated in the regulations that it is allowed.
Presumably to allay people like Winston - although it hasn't worked in his case.
I would say yes, provided you moved the two sockets to another circuit first, because it would become a lighting circuit.
accusing anyone of lacking brain cells is an insult which should not be tolerated on these forums.
giving incorrect information is just as bad and should not be tolerated,
Your opinion about 13 sockets on lighting circuits is your personal opinion and is counter to the information in the regulations.
One does wonder if your zeal to push your opinion stems from something you did or experienced when using a 13 amp socket on a lighting circuit.
Regs change as necessary and no doubt this one will change in time.
I very much doubt that it will change as it is not necessary to change it.
Slight tangent, but does it have to be a Nest camera ? Maybe you could install a camera which runs POE then you only need Ethernet cable to a DVR.
Can you please tell me which regulation states that if you add lights to a circuit which has sockets it must be re-designated as a lighting one, because I can't find it.
Status
