Wiring a CM927 into a Worcester Bosch 240
30 May 2006
Leicestershire
I have a well maintained WB240.
It currently has a sunvic select 207 digital timer etc.
Wired in as follows:
N= N blue
L= L brown
T1= blank (hw off)
T2= blank (ch off)
T3= black taped (hw on)
T4= black (ch on)
X10 panel on boiler wiring:
1=black (ch on)
2=black taped (hw on)
3= brown 230v L
4= blue N
I have purchased A Honeywell CM927.
From what I can see I will need to rip it the old timer and reattach the old switch on the front cover and set this to constant hw.
Wiring to do:
X10 term 1 to grey, leave disconnected as the cm927 will control this circuit or do I connect it and leave constant????.
X10 term 2 to white to control water either on or off.
X10 term 3 to brown 230v L
Now on the CM927
I would like to use the isolated switched live and neutral from the digi timer but it gets the power from the combi.
I could resite the RF unit closer to the boiler in the loft and then tap direct from the mains switch etc.
this is the plan.
N = neutral from mains
L1= live from isolated mains
L2= live jumped from L1.
A= boiler Terminal X4 pin 1.
B= boiler Terminal X4 pin?
This is where I'm stuck I'm left with X4 pins 2 or 3, I'm thinking 2.
Pinot for the thermostat on a 240 is
1. Live IN
2. CH ON
3. NEUTRAL
I'd rather ask a question
I suggest you retain the existing Sunvic timer to control HW. Just set the CH to permanently off.
As for the CM927:
L to X10/3
N to X4/3
A to L (link)
B to X4/2
Alternatively you can set CH permanently on at the Sunvic and connect L to X4/1.
What looks like a variable resistor is the anticipator, which is only found in mechanical stats.
I must admit I prefer to keep the sunvic as it has been extremely reliable,
Just setting the Ch to off, great
So I'll link the two L's and then link A.
Ok I've taken the live feed direct from the mains supply terminal below the terminals x10 as it was neater and closer.
Thanks guys it works a treat. :mrgreen:
All in all I'm very impressed, I should've done it years ago, it as also recommended by the British gas engineer as well.
I short listed two this and the Siemens unit.
