I'm installing a Texecom Excel panel with EOL resistors (10k & 22k). As far as wiring in the PIRs I'm ok, but not so sure when it comes to wiring in a door contact.
One core will go to one side of the alarm terminal in which there is also one leg of the 22k resistor. The other leg of the 22k resistor is soldered to the 10k and both go in to the other alarm terminal.
The other leg of the 10k is then soldered to the remaining core.
Is this correct?
Is this correct?
