Im trying to wire in an outside light and have wired it through an internal light switch,what type of switch will I need a 2 gang 1 way or 1 gang 2 way ?
Please help !!
So as its a double switch both need a neutral ?? As the outside light is working with no nuetrual but as soon as inside light switches on outside goes off ??
Describe what wires were at the switch originally.
Switches do not require a neutral connection; they only switch the live.
However, your new light will need a neutral connection.
Remember that blue or black wires in switches are not necessarily neutral.
When the new light works, does it appear dim?
Is the original switch a 2 way one, ie another switch also controls the same light?
Is there a set of black or blue wires in a connector block tucked inside the switch box by any chance?
