wiring a Drayton LP722 into a nest
19 Mar 2019
I believe I have a s-plan heating system.
I have looked in the airing cupboard and found 2 valves. One says for hot water
The other says Zone valve but I dont think it is a Y-plan as there are only 2 settings.
Am I correct?
Here is the wire for my Drayton LP722
Is it as easy as:
I will need to split my one live going into 1 into 2 wires that go into 2 and 5 on the nest
Does that all seem correct?
My only question is what do I do with my wall mounted old thermostat?
where does the wire in terminal 1 on the existing programmer go ?
Hi Ian,
There is a blank faceplate next to the programmer. it goes into there and into a wire jungle. I could trace it once Ive switched the power off
cant understand what it could be used for , that terminal is used for a 3 port mid position valve and not used in an S plan as you have unles at one time there was a motor open motor close 2 port valve at some stage , the ones you have just now are spring return and wouldnt need this wire
