Hi, I'm renovating a kitchen and replacing a oven/hob with a dual fuel range (Rangemaster Elan1100). According to the specs the max load is 7.4KW for this range. I need to move the CCU so will need to reroute cabling.
I've a couple of questions regarding MCB and Cable size.
1. Is a 32A MCB sufficient or do I need to go higher (35A) ?.. It will be a dedicated feed to the cooker i.e no socket off the CCU.
2. Will 6mm cable suffice? The cable will run from the Fuseboard directly into the atttic (it's a bungalow) and will run on top of fibreglass insulation for about 15 feet before coming down to CCU in trunking (chased behind plaster on solid wall for about 6feet drop). or will I need 10mm ?
Appreciate any feedback .. Thanks.
