Hi
I need to put in a supply for a log cabin, I have power to a shed nearby (10m away from the cabin) via 2.5mm inside plastic conduit. Can I take a supply from that or do I need to upgrade the whole supply to 4mm. The shed supply is taken directly from the consumer unit protected via a 15A MCB. The load on both the shed and cabin will be quite low, occasional power tools and lighting there are no appliances left on in either. I have a unit with a RCCB and 2 MCB's I can use, should I put that in the shed (currently only protected by a old consumer unit wire fuses and no RCD) or in the cabin.
Steve M
Steve M
