Mira Azora 9.8 Kwh electric shower; the manufacturer's instructions show the wiring sequence as.....30Ma RCD on Consumer Board to Double Pole pull switch (I'm using a 50 amp DP with neon and flag pull cord switch) then to Shower.
Question: should there be a 45 amp MCB also fitted in the circuit and if so; where in the circuit should it be situated; just before the Consumer Board ?
I will not be doing any work involving the Consumer board connections.
