wiring a second light from one switch
30 Dec 2009
Cumbria
Hi, I'm a new member and i have a (hopefully) simple question:
I want to fit an extra ceiling light in the bedroom, worked from the existing switch. The existing ceiling rose is fed by 3 red wires, 1 black and 2 earth. Do I just run 1 of each colour (using standard twin and earth cable) to the new ceiling rose? Thanks.
Do I understand that you want to add a second light that will come on at the same time as the existing light?
If so, just run a piece of twin & earth cable from the existing ceiling rose (connected to the same terminals as the existing lamp) to the second rose.
There is a drawing of this in the WIKI. At //www.diynot.com/wiki/electrics:lighting:parallel
It is a mmuch bigger issue if you want to switch them separately.
Is it me or is that diagram a bit misleading for a novice? It seems to suggest conecting the new light to the supply (CU or previous light) with no switch connection shown.
Think the first diagram is easier for a novice to follow but something you all forgot to tell him.
Isolate the circuit at the consumer unit first!
Just because you switch off at the switch does not make the ceiling rose dead.
Simply because he is only connecting from one rose to another and doesn't need to see how they are wired back to the switch if he is controlling both lights with the one switch.
Unnecessary detail basically.
