Wiring a security light
5 Sep 2008
I have recently connected an outside security light with built in sensor by passing the wire through the wall and simply plugging it into the nearest socket.
I am planning to place another security light and was wondering if it would be ok to use the following set up:
Plug with 1.5mm 3 core flex connected to a junction box and then the same type of flex coming from the junction box to the two security lights?
Also
Is it ok to place a junction box outside??
Thanks for your help
Isn't it normally the preferred practice to connect exterior lights to the light circuit, not plugged into a plug socket?
What I did when I fitted my external light, is take a spur from the bathroom light. Ran a cable to a FCU, then through the house wall into the light. You can then connect another cable from the switched live from the PIR to another light (I think )
It's best to review the circuit loading and the new light loading first.
A 6A circuit can only supply 13 standard lamp sockets. A single 500W security light would use 5 of these up, leaving a capacity of 8 lamps on the rest of the circuit.
A 5A circuit would only supply 11 lamps positions.
If it's getting tight, a FCU from a ring final would be preferable.
Thanks for your replies.
I have a very basic knowledge of wiring and electrics (changing plug sockets, light switches) and so I would not want to tamper with any of the circuits.
It is a 300W security light that I have connected using this type of flex
http://www.screwfix.com/prods/61570.../3-Core/3183TRS-0-75mm-3-Core-Flex-Black-25m#
I have connected a plug and run the flex along the skirting board and along the wall and then passed it through a hole I drilled in the wall connecting it to the light.
Is this setup safe?? and would it be safe to add another 300W light??
