Wiring a Tank Stat and diverter valve for use with a rayburn
26 Apr 2011
Somerset
Hi, I have an old soild fuel rayburn that has been converted to run on oil. The conversion was done many years ago and runs fine. Recently I have had the entire plumbing in the house re-newed. The heating system is configured to gravity feed the tank and also 1 rad to reduce the risk of the system overheating (this can be manually turned off). There is a diverter valve and a tank stat (wrap around the tank type) that need wiring. Obviously the rayburn has manual controls so any controller will have to just read the tank temp/room temp and control the diverter valve and CH pump. Could somoeone advise me of the most straight forward way of achiveing this?? Im assuming I just need a controller?? im not bothered about a room stat
GAHC
