Wiring a Wickes thermostat
14 Feb 2012
Yorkshire
Hi there,
Help in wiring a simple Wickes thermostat please!
I am installing a tubular heater in my shed simply to take the chill off whilst working there.
I know the wiring instructions are included but alas I cannot make heads or tail of them!
I have installed both heater and thermostat but the heater comes on at a warm temperature and goes off at a cold temperature!!
So where have I gone wrong?
Help!!
Regards
Alan
You have wired it as make on temp. rise. You need to wire it as per the instructions for break on temp. rise.
For information a tubular heater will not provide a great deal of heat seeing as they are only a few hundred watts at most and the insulation in a shed is next to zero.
Thanks for your response. However thats the problem how do I wire it correctly? To me the instruction are a little misleading to an old fogey!!
Hiya,
Many thanks for your help.
I have posted a photo of the instructions but I am a little unfamiliar of how to attach it to this message.
All I need to know is where two wires go in and where 2 wires come out!!
If you can't find it I could always send it to your email address.
Many thanks
Alan
Hi there!
Many thanks indeed for your response to my problem.
I was a little confused 'cos I had simply wired the thermostst up as previous one.
Imagine my surprise when it switched on when hot and off when the temp fell !!!
I shall give it a go, hopefully this weekend.
Once again, many thanks,
Alan Radford
