Wiring Alarm Circuit
22 Jan 2007
Fitting some Mains wired smoke alarms in the house, and also hard wired Carbon monoxide detector. Now the fire alarms have 9v battery backups but the COD doesnt,
I was wandering if wiring the hall light onto the citcuit would contravene regs?
Just so if it ever did trip for any reason I would be alerted to the fact reasonably quick. Alarm circuit is on 1.5mm T+E on 6A RCBO.
It is acceptable to supply smoke alarms from a regularly used local lighting circuit.
But should they have an independent isolator, if using this method?
Wiring of smoke alarms
The detectors are required to:
a) be linked, so that the operation of one will initiate all
b) be permanently wired with independent circuit to CU or supplied from local regularly used lighting circuit. (there should be a means of isolating the supply without switching off the lighting circuit).
c) have a standby power supply.
Not that I'm aware of unless it's specified in the MIs.
I'm of the opinion that the harder it is for them to be isolated the better.
