wiring an Ideal Wlx
19 Sep 2004
i have just bought flat which has an Ideal WLX CF 40 system boiler
The room stat was broken so i replace it with a new one today but it doesn't swith off the boiler .
i checked the wires with a multimeter and get zero voltage.
Had a look at the wiring . It is all wired into the progammer .
there is live , neutral and earth to the programmer , then another live neutral and earth connected to the same terminals, then there is the wires for the room stat and cylinder stat
i think the wiring has been altered but how should it be wired into the programmer so i can get the roomstat working again ?
Read THIS and supply the information that is applicable.
You should follow the instructions that came with your programmer and your room stat
The new room 'stat may be ok, but the cylinder 'stat could be 'calling ' for heat from the hw channel of the programmer.
