Wiring Boiler Timeswitch - Danfoss 103E7
7 Feb 2006
Leeds
Good evening can you help me please?
I trying to install a external central heating timeswitch but the wiring diagram only shows it with a room stat which i don't need and I'm getting confused.
I've added diagram of what I currently have (thanks breezer if I've added it right) but here's a description if not.
Mains supply to boiler terminal via 3A FCU
Boiler terminal has:
L3 - N - E - L2 - L1
L3 has brown live
N - Neutral
E - Earth
L2 & L1 - loop
load
L3 - brown live
N - Neutral
E - Earth
L2 - Black?
L1 - Loop to L3
Timewsitch
1 on
2 Spare
3 com
E
4 Neutral
5 Live
I'm sure this is straight forward but I struggling
Many thanks
detail
[/url]
it shows it with a stat becasue you do need one (its a building reg thing)
Didn't realise that regs required room stats, please excuse my ignorance but why?
Many thanks
you need to run from the connecter block in your boiler a bit of 4 core flex, L3 to L, N to N and the S/L side of link to the ON terminal
it may also req a link between L and C check clock instructions
this is also providing you boiler works with 240v external controls. some are volt free. please check boiler installation guide
room stats are part of regs now for effeciency
Gents
Thanks for that I'll give it a go, but regarding the room stat are these required in addition to valve stats?
dizwoz said:
Gents
If you mean the stats on radiators (they are called TRV's) then yes you do require a room stat too, also one rad (usualy bathroom) should have no trv
its because if they all close where is the water going to go? (it cant) i learnt all this from the plumbing forum
Many thanks
Sorry, diz, but if you have to ask basic questions like this, you need to swot up before you can complete the job...
Thank you all the timeswitch is working perfectly together with new room stat.
Thanks you also Securespark I'm sure there are lots of parts to the building regs that I don't know thats why I come on here and seek your expert advice and it's much appreciated.
Until next time!
Cheers
Until next time!
Cheers
May i suggest you do as i do, read, its entertaining and true
