I want to install Honeywell CM927 thermostat (I don't currently have a room thermostat, only Landis&Gyr RWB200 programmer).
As I understand it, I need to wire the Relay box BDR91 that comes with CM927 into my Honeywell Wiring Centre. Unfortunately, I can't find the wiring diagram for this combination anywhere.
The Relay box has N, L, L, A, B, C contacts - see page 3 here: http://www.honeywelluk.com/Documents/Installation-Guide/pdf/1069.pdf
The Wiring Center has terminals 1, E, 2, 3 for "Room stat" - see page 23 here: http://www.honeywelluk.com/documents/All/pdf/Wiring Guide Issue 16.pdf
Which should I connect to which?
