Hi. I intend to install a selection of ionisatio and optical smoke alarms and a heat alarm. They will be Kidde mains interlinked alarms on a dedicated circuit from a consumer box.
The alarms all come with three short (10 inch) soldered electrical tails viz. positive, negative and white interlink which will be interlinked using 1mm flat 3 core cable. All alarms will be ceiling mounted and accessible from the floor above except for one which will be a beneath a flat roof cavity but can still be accessed through the ceiling.
I should be very grateful for any comments, suggestions, etc re the following questions please:
First relates to the interlinking between the alarms. Can I connect the three tails to the flat cable using "chocolate" connections or are there better alternatives?
Secondly, I understand the link from the consumer box and the first alarm in the series should be three core but in this case 2 core plus earth. As there is no actual earth connection, I am puzzled by the purpose of the earth lead.
Many thanks in anticipation of your assistance
