I've done some research on wiring in my new oven I just wanted to check that I have everything right before wiring it up.
Oven Indesit FIU20
http://www.manualslib.com/manual/76642/Indesit-Fiu20.html?page=29#manual
I've bought a metre of 6mm cable to connect the oven to the terminal in the wall behind my existing cooker. The manual recommends a minimum of 4mm so I believe this will be fine.
Another issue I have is at a later date I will be connecting a hob too. The manual state a 45amp double pole switch should be fitted. what implications does this have on my main fuse box?
Oven Indesit FIU20
