- Joined
- 9 Feb 2017
- Messages
- 14
- Reaction score
- 0
- Country
Hi all,
Currently in the process of having to wire in a new electric oven. The old oven is wired into a dual connection unit along with the electric hob. The instructions for the new oven state:
For 60cm BI appliance: 1. Where a fixed connection is used, a device allowing the appliance to be isolated on all poles from the mains supply with a contact opening width of at least 3mm must be provided. Use a 13 amp fuse. 2. A type HO5 V V-F cable must be used as the mains lead. The cross section must be a minimum of 1.5mm².
I'm taking that the oven is 60cm as I have measured the height and width which both appear to be near to 60cm. However, does this mean that the oven will need a 13a plug fitted and plugged into a 13a socket? I thought I could do this without worrying about Part P but i'm thinking otherwise now.
