K
Klaus_K
I want to run electricity to a new garden shed that I have just build. My consumer unit has an empty slot so I was planning to add a new circuit breaker and run the cable from here. My plan was to wire this cable along the outside of the house, up into our loft, and then to add a junction box to connect the cable to some armoured cable that I will run along my garden fence to the end of the garden.
The electrics will only be used for low power equipment, such as audio, amps etc, so I figured that 16A ought to be ample.
Can you confirm if this is OK - and is it legal (my wife has warned me that it is now illegal to do home wiring in the UK.
As a final protection, I thought that I would put an RCD circuit breaker in the loft, in such a place that it can be accessed and tested/reset if necessary.
Any advice will be most gratefully received!
