- Joined
- 6 Feb 2020
- Messages
- 3
- Reaction score
- 0
- Country
Hi I am fitting 3 electric hobs (domino hobs so 30cm induction/30cm grill/30cm teppanyaki) on an island with them being 3kw/3kw/3.7kw loads and each has 1.5m flex cable. Do I need to take 3 x 6mm T&E from CU to each one via separate cooker switches or can I do with less cabling e.g. 1 x 10mm T&E and only 1 cooker switch on basis they are 1 conjoined hob unit. I suspect I need 1 x 10mm to service the 2 x 3kw = 6kw from 1 point and 1 x 6mm for the 3.7kw as all 3 hobs could be on at the same time?
