marksecond said:
i) a FCU above worktop feeding a flex outlet below
The main issue with that idea is it requires the appliance to be hardwired... not going to be good on removal day, and wires the new owners of the house to wire their machines in, and the old ones to re-fit BS1363 plugs, if you think back to why the 1994 plugs and sockets regulations were brought in (even though they can't directly be applied here) it was because a lot of people make a dogs dinner of even wiring a plug (I've lost count of how many times I've had to re-do them for people!)
If you do use this idea, might be wise to use 15A BS546 unfused S/O and plugs, that makes the issue a little less and also allows the washing machine service engineer to physically disconnect it before working on it.
Done with 15A plugs and sockets its not a bad way of doing things IMHO, but still has its faults
ii) FCU above worktop feeding unswitched socket below
Two fuses, not really that great as they'll fail to discriminate, also if the one behind goes you've got to pull the machine out (but chances are if it goes, the machine probably needs pulling out in order to fix it anyway....)
iii) 20Amp DP switch above worktop feeding unswitched socket below
Still the minor issue of hidden fuse, but at least it'll discriminate, slight issue here is if you are using a 32A circuit and use the supply terminals of the switch to loop through onto the next, etc... that could be seen as a non-compliance by some, its not like a SO or FCU where it'd been designed to do this, and while the terminals are probably the same, maybe bbest to ask the maker for conformation that the terminals are suitable for this?
PS Does a gas hob igniter just have a flex. Should this be controlled by FCU or switch or can it just go into flex outlet or socket??
Do it the same way as you do the rest of the appliances, but fit 3A fuse
(In final year of C&G 2330 but limited practical experience!)
I'm still on the part 2, shouldn't it be you giving me advice?
