hi
im looking to run 3 bulkhead lights outside which i want connected to a photocell. however i dont want the lights to remain on all through the night so want to add a timer to the circuit. i could just use the timer but this would need constant adjustments when the nights start to get darker/lighter so would like the photocell to do the job of determining when its dark enough to switch on the lights
i have a greenbrook timer, model T40S-C
http://www.greenbrook.co.uk/product-pdfs/T40S_Ins.pdf
the photocell is pretty standard with 3 screw connections, Line, load, neutral
The issue i have is getting my head around how to wire the timer into this circuit as the manual for the timer is pretty poor and does not explain very well how to wire the unit in. does my brown live wire connect to the live connection of the timer and do i then take another brown live wire from the load? what about the blue neutrals? do these just need to be connected together and not to the timer switch thus bypassing the switch and going straight to the photocell?
if anybody could help and possible provide a diagram i would be most greatfull.
Chris
Chris
