Wiring for replacing 12v MR16s with 240v GU10s
27 Sep 2007
Lancashire
Hi
Is this acceptable ?
run 240v switched supply using 2 core cable to each GU10 connected in series using ? connector terminal blocks (choc blok) because the covered round terminal units are too large to go through the downlight apertures ?
thanks
Not an earth conductor but a circuit protective conductor!
If using choc blocks they must be enclosed to prevent accidental contact to live parts and they must be accessible for maintenance, inspection and testing.
