Wiring for Security Lights
23 Jan 2003
I sorted all wiring out for 3 security lights to work off one switch in kitchen (with the exception of tapping into the lighting circuit) ie all cables chased through o/s walls ready. I then purchased the lights (1 x 500W and 2 x 150W) only to find they are to run off the ring main using switched spurs!
I am sure in my previous house the security light was connected to the lighting curcuit!
Is there a way around this without replacing all I have done and repeating with power cable and replacing existing light switch with fused spur?
Your advise would be appreciated, Thanks :mad:
yes you can run it off the lighting circuit, it may be easier to take the cables you have to the lighting cisuit and connect it via a j.b there.
There is only one concern, that of how much load you will putting on to your existing lighting circuit.
Thanks Breezer. Can I ask you how I can measure whether I am overloading the lighting circuit or not? :)
