Hello, appreicate this question might have been asked before, I can see similar has been asked in this forum and elsewhere but I'd like to be clear on how to do this, all ideas and comments very much appreciated.
I would like to add Underfloor Heating to an existing combination boiler, my questions are around the electrical/control side, not the plumbing. The existing combination boiler has a built in timer that controls the central heating system which is currently all radiators in a single zone/circuit. I would like to add wet underfloor heating to this which has a pumped manifold. I am aware that the usual means to add Underfloor Heating is to connect it as a separate, second zone, with it separated using zone valves and the thermostat for the underfloor heating triggers the boiler to provide heat via the Switch Live electrical input on the boiler. However......
A. My boiler does not have an electrical output to connect a zone valve, so when the built in timer on the boiler goes to turn on the radiator central heating, there is no means for it to actuate a zone valve
B. I only want the underfloor heating on at the same time as the radiators, there won't be an occassion when the radiators and underfloor heating are on at different times, so no need to have this in a separate second zone. As such, I want to plumb in the underfloor heating manifold (blending valve) to the main central heating circuit so the whole system remains as one zone. I don't see the benefit in using zone valves as my house is not big enough to warrant multiple heating zones and I can see others are not recommended zoning heating anyway.
C. My boiler does not provide an electrical output to connect an external pump, so I don't see a means to connect the pump on the underfloor heating manifold to the boiler.
I can think of 2 ways to achieve what I want:
1. Provide some sort of feed from the timer on the boiler to turn on the pump at the underfloor heating manifold. I think this will need some sort of relay and an electrical connection from the boiler, though unclear as to how this can be provided.
2. Disconnect the built in timer in the boiler, instead use an external timer that controls both the underfloor heating and the main central heating. This will necessitate providing a Switched Live connection from the timer to the SL input on the boiler. This looks to be the best solution.
Any comments/ideas?
Many thanks.
Any comments/ideas?
Many thanks.
