i have just had a new window fitted in my kitchen and at the same time the fitter put some wiring through the walls for the wall lights.
I'm not sure if the way it has done is ok or not.
basically, the old switch wire and wire from the previous ceiling rose (not now being used) are wired into a block that is in the wall.
From this comes the main wire to the 1st wall light position, this is then looped onto the next wall light position. This then goes over the ceiling to the other side of the kitchen where there will be some more lighting (under cupboard etc).
However, there is a 3rd wall light position, but because the fitter didn't have time to chase this into the wall, this will have to come from the 2nd wall light position.
Basically I want to know if this will all work?
Thanks in advance.
Thanks in advance.
