Hi
I have a vokera linea 24 boiler and just purchased a Honeywell cm 907 thermostat. The vokera boiler has an internal timer.
I attempted to install the thermostat and currently have it working but with the internal timer.
So in my boiler I removed the link which was from TA-TA, The internal timer was going into the TA as well. In the thermostat I fed two wires from A and B to the TA. Also I connected a loop wire from A – C which is internal within the thermostat.
But I am stuck as to how I can run the thermostat without using the internal timer? It is battery powered so no Live.
It seems I need to do what the internal timer does but from the diagrams for both the boiler and thermostat it does not seem clear
Please could someone assist
Cheers
tj
Cheers
tj
