Wiring in a new controller.
10 Sep 2006
I've picked up a new wireless controller (CMT927) and need some instruction on where to place the wires.
The old setup was thus:
2 pairs of wires (brown and blue). One coming from the switch below. The other leading to the boiler.
The three holes across the top are NC / COM / NO. The two across the bottom are N / L.
I've wired half of the new receiver, the supply coming from the switch, but where should I put the other wires?
Just had a thought - my boiler has a mechanical timer. Should I just leave in the perm on position? Or would I be better to remove it entirely?
Assuming wired correctly at the boiler -
Brown to A (live),
Blue to B (switched live).
The Blue to the boiler should be sheathed or taped in brown.
Connect the CPCs (earths) together in a connector block and position safely.
Leave the boiler CH on permanently.
Thanks.
There are no earths. :confused:
Edit: All hooked up and working a charm.
