WIRING IN BATHROOM EXTRACTOR - HELP?!
5 Apr 2011
Hampshire
Hello all,
MY first post on here!
Im looking to add a bathroom extractor fan - I have purchased the MANROSE VXF100T with overrun timer. I want to add this to the lgithing circuit so that the fan comes on automatically with the light.
Can anyone talk me through this?
Rob
Here's the wiki link
//www.diynot.com/wiki/electrics:lighting:fan
What are you having trouble with ?
You need a live, neutral, switched live and earth so 3 core TE is required.
You need to buy a 3 pole fan isolator and then feed between the existing permanent live, neutral, switched live and earth from source to the 3 pole isolator.
From there you run the 3 core to the fan.
The fan works in two forms, first a simple on controlled by the activation of the light switch. Then when the light switch is turned off the fan will still have a live feed (via the permanent live) to continue to work for a timed period.
The 3 pole unit is required to isolate the fan for cleaning and service without turning the lights off at the same time.
