can anyone tell me what the white cable in immersion heater is called i.e. live negative or earth. it goes from one side of thermostat to a short rod in thermostat.
As breezer has unhelpfully pointed out, it can be either live or neutral. However, it can't be an earth.
It's conventional to connect the live (aka phase) into the thermostat, then the thermostat to one element terminal, then the other element terminal to the neutral, so the best answer to your question is "live, probably".
