Hi and good morning
I'm just about to install a single beko oven that needs a 13amp fused spur and an induction hob that requires a hardwired 32amp supply with cooker switch.
No problem with the induction hob, as I have a 32 amp dedicated supply already installed. My question is, can I use an existing 13amp plug socket below the worktop, with no on/off switch, but it's operated via a switched fused spur above the worktop?
I would put a new 2.5 cable into the cooker with a normal 13amp plug.
Obviously then, I would have two fuses, one in the newly installed plug and one in the existing fused spur.
Is this ok?
Is this ok?
