i suppose that you are familiar with the zone contacs on the alarm panel being closed circuit and also on the viper you have a closed circuit alarm contacts as well
take 1 wire from one side of the zone you are wiring to on the control panel and take it to one side of the viper closed alarm contacts and from the other side of the viper closed alarm contacts to the next viper closed alarm contacts and from the other side of the viper closed alarm contacts to the next viper and the last viper closed alarm contact take the wire back to the other side of the zone you are wiring to on the control panel and do the same to the tamper circuit wires wiring them to the TAMPER CIRCUIT
also the positive +----+----+and negative _ ---_----_wires the same but the last viper you wire you don't need to take the wires back to the alarm panel hope this helps IF YOU DRAW IT ON A PEICE OF PAPER FIRST IT should MAKE SENSE
