Hi all, if I could just tap into your experience it would be great!
In your experience what are the pros and cons of wiring a house in twin and earth clipped and drilled through joists, and alternatively installing a conduit system?
I' don't want you to do it fot me, I just want to see what I've missed as I'm sure most of you will know all sorts of hints and tips to make life easier or financially rewarding!
Heres what I've thought of:
T and E
cheaper than conduit system and quicker to install
however drilling holes may weaken the buildings structure and also presents a risk to someone screwing or nailing something into the wall when eg. trying to hang a picture
Conduit
In theory should make a future rewire a LOT quicker and less messy. provides better protection to cables, essential to use on solid brick walls in houses, Also provides option of using single wires rather than T&E(?????)
However, more costly and time consuming, may not be necessary, if using metal conduit it wil also need to b earthed. Could make later modifications (ie adding socket to a ring) more difficult.
Im sure I've missed some points so can anyone give me some input?
Cheers
T and E
Conduit
Cheers
