Hi, I'm looking to install a Nest 3rd gen thermostat for my dad's house. His boiler is Vaillant turboTEC plus and wired to another room with controller/thermostat (VRT 330).
Did some search on the forum and I believe I need to:
1. wire the boiler L/N to heat link L/N;
2. Take off pin on boiler 3/4 and wire to Heat Link 2-3;
3. either use 7/8/9 connects to heat link T1/T2/E or I can run the Nest thermostat on usb power and just remove the cable from boiler connector 7/8/9 (prefer the later as the current thermostat is behind curtain).
But looking at the Nest Heat Link connectors, 1-3 is for heating, 4-6 is hot water. So if I wire it as above, what's controlling the hot water? The control panel on the boiler sets the water temp for hot water and heating separately but I don't see any wires for hot water that I can run into the heat link?
below is the current setup:
View media item 103623View media item 103624View media item 103625View media item 103626
