I am wiring a double dimmer switch, which was taken off by a decorator and replaced and now we seem to have a problem with a circuit of the lights in 1 room so I am trying to identify the problem starting by making sure the switch is not at fault.
I have attached a picture of the switch how it is connected does it all seem right? One picture shows the wires coming into the back box and the other picture showing the connections on the switch.
There are 2x (2 core + a bare wire?) The two bare wires are both connected to the metal back box.
I might also trying wiring it up to a standard double switch and to check if the problem is the switch itself, the wiring should be the same with a standard double switch and a dimmer double switch?
[/img]
[/img]
