I've just replaced my old Honeywell T6360 room stat as the old one stopped working. I'm not very experienced in matters of electricity so to make things easy for myself, I simply bought a brand new one (i.e. the same model) so i could just copy over the wiring. All went fine. Just one query - the new Honeywell T6360 has a small LED on it with is illuminated when the unit "calls for heat". I was just wondering if there is an easy way of using my existing wiring to connect up the LED, or if additional wiring is needed?
The wiring info for the room state can be found here > http://content.honeywell.com/uk/homes/Catalogue/Heating Controls/2.17 T6360.pdf
Currently, the earth wire (yellow/green) goes to the earth connection, neutral (blue) goes to connection 3 and the live (brown) wire goes to connection 1.
Am I right in thinking I could just use the neutral wire and connect this to connection 2 as well as 3?
Thanks in advance for your help!
Darren
Darren
