I have just moved to a new house (built 1979).
Someone in the past has installed an outside light using 3 core and earth, and running the wires through the outside brick joins to the hall ceiling light. Then another piece of 3 core and earth is connected from the ceiling rose in the hall to the switch.
The switch is a two gang switch, one for the hall the other for the outside light. The live feed for the switch comes from the hall light switch live feed.
Basically I am not happy in the way it is wired as I don't think it is right and wish to run proper 1.5mm T&E cable to the light and switch. However I am unsure the best way to run the cable.
Is it best to drill a hole right through the wall where the outside light will go and then chase up the inside of the wall to the ceiling to connect to the hall light as a feed. The cable from the swich could then be run the same path to the outside light. Or is there a better way to run it without chasing the inside wall out.
Many thanks for any suggestions.
Adam
Adam
