Hello
My existing built in single oven is connected to a cooker switch using 6mm 40 amp cable a pretty standard setup.
We are planning to replace it with a similar oven, but the new one is hard wired with a 13 amp plug, because it has a maximum output of 3KW.
How would you connect this up please? I am tempted to cut off the 3 pin plug and connect it to the existing cable using a junction box.
