Wiring phone extension directly to phone line
16 Apr 2011
Manchester
Hi.
I need to directly connect a blue/white orange/white etc. phone line to an extension that has yellow, green, red and black.
Is this possible and how do I match up?
Have searched the internet to no avail.
Thanks a lot.
hi sounds like someone has used alarm cable look on back of socket connect blue/ white to 2 white/ blue to 5 orange/ white to 3 the blue/white and white blue are normally the middle two but i have seen some other configerations.
It might be alarm cable, but with those colors it might also be flat modular telephone cord. Red/green/black/yellow are the standard cord colors which have been used in North America for many years, with red/green as the first pair and black/yellow the second.
Some of the cheap Far Eastern extension kits sold in Britain now use the same cordage with U.K. connectors. If a BT431A plug is crimped directly to the end of the cord, then the line will end up on the black/yellow pair, with the bell feed/shunt on either red or green. But some other kits connect only two wires, using the red/green pair. There's no way to be sure without further investigation.
Thanks.
Based on your best guess, which colours would you reccomend trying to connect together first?
Black Red Green Yellow are 2345 respectively
If this is flat modular cord with a BT431A plug on the end to connect it, just be aware that the sequence might be the opposite way round. A phone will still mostly work with the line (2 & 5) swapped, but might not ring on incoming calls without the ringer feed (3). Many new phones don't use this third wire now anyway though.
And possibly it is multi-stranded wire which will not connect properly into IDC ( punch down ) connectors. It will probably work for a few days and then fail.
