Wiring Pull Cord Switch for Extractor Fan
7 Mar 2006
Shropshire
Please can you tell me if this is right
i have a pull cord switch with the following terminals
comm
l1
l2
coming into this switch i have incoming live, neutral and earth
also going to extractor is 3 core red, yellow and blue
does the 2 reds (incoming live and perminant live to extractor) go into L1
YELLOW Switch Live go into comm
2 Neutrals Blue do these go into 5amp connector block pushed into the switch
both earths connect into earth terminal
can you confirm this is right
cheers brett
it will work yes, but perm live is normally in the C term but there should be 3 pole isolator feeding the fan. how will you know if you have pulled it properly to switch it off? if you accidentally double pull it you wont know where you are with it unless you use a neon pull switch. anyway it will work
