Wiring standards T586A & T586B
9 Nov 2005
Wiltshire
Generally, where are theses two standards used.
Is there any rule as to where they are used or can be found?
TIA-568-A is no longer used, TIA-568-B superseded it and is used in All permanent links and patch cable wiring.
Whats your application?
I have just installed a small network and noticed the connectors colour coded for both standards and wondered what TIA-568-A was for.
Thank you for your response.
Wikipedia claims
"Perhaps the widest known and most discussed feature of TIA/EIA-568-B.1-2001 is the definition of pin/pair assignments for eight-conductor 100-ohm balanced twisted-pair cabling, such as Category 3, Category 5 and Category 6 unshielded twisted-pair (UTP) cables. These assignments are named T568A and T568B and they define the pinout, or order of connections, for wires in 8P8C (often incorrectly referred to as RJ45) eight-pin modular connector plugs and sockets. Although these definitions consume only one of the 468 pages in the standards documents, a disproportionate amount of attention is paid to them. This is because cables that are terminated with differing standards on each end will not function normally.
TIA/EIA-568-B specifies that horizontal cables should be terminated using the T568A pin/pair assignments, "or, optionally, per [T568B] if necessary to accommodate certain 8-pin cabling systems." Despite this instruction, many organizations continue to implement T568B for various reasons, chiefly associated with tradition (T568B is equivalent to AT&T 258A). The United States National Communication Systems Federal Telecommunications Recommendations do not recognize T568B."
A is the less confusing scheme since the middle pairs are wired the same as for smaller RJ connectors.
If your working on an existing installation I would stick to whatever the existing wiring uses.
