Hi all,
Most of the light switches in the house where there is more than one switch operate not how you would expect, as in the switch nearest to the light should control it so I started to fix these yesterday.
The utility has a pair of switches. Unfortunately I got distracted when changing the wires over and may have mixed one up, I think there were 6 wires, one to each of the COMs, L1s and L2s - all of the wires are red and they are not labelled.
The switch on the left should be for the utility light, it can also be controlled from the kitchen. The switch on the right is for an outside light.
If the switch on the right is on, everything else works OK, if its off, all of the rest of the lights turn off. The outside light does not work at all.
If I disconnect one of the wires, the outside light will turn on and off but none of the other lights then work. The COM is permanent live.
How do I fix this please?
Thanks in advance.
Thanks in advance.
