This is my first ever post - so please go easy on me. I appologise in advance if I have made some fo pa unwittingly!
I am considering installing a new Vaillant 24w Combi boiler in place of the pressurised (converted) Apollo Fanfare unit. This is reliable, but not very efficient, slightly underpowered, noisy and obviously old. The current system has been converted to a pressurised system with the addition of a filling loop and expansion vessel. Apart from that it's bog standard.
Other considerations. I have a very nice expensive shower pump and all the associated, plumbing; tanks, gubbins etc which I am keen to keep in place. I am quite happy for the honeywell Y valve to continue to be used in the old way to do tank HW and CH. The intention is for the DHW on the new boiler would just provide the sinks and bath with hot water. This is becuase I don't want to install much bigger than a 24kw boiler and even though I have excellent mains pressure - 9l pr min at + 35c from input is just not enough for the shower.
Questions: ?
1. I think I know the answer to this one... I presume I need to remove the existing Pump and Expansion Vessel since the new boiler will have them included and there is no easy way to remove them from the new boiler?
2. Is there any reason why the thermostatic electrical input on the new boiler can't be used as per the old switched live on the Apollo Fanfare - thereby allowing me to occasionally heat the water in the tank for a shower from the new combi boiler?
Thanks very much for reading and any answers/oppinons you provide, in advance.
Questions: ?
