I've asked about this before, in passing as it was a job I was getting round to doing, but never did. Anyhow my father in law was helping out in the garden and managed to find the buried conduit i had been telling him about 5mins earlier with a spade, for now i've disconnected the outside suppy at the source.
Currently the supply to the shed is/was fed from the back of a double socket on the downstairs ringmain which isnt ideal, this runs in some buried plastic conduit to my brick shed/outbuilding, at this point it goes to a single socket then a spur from this to an FCU feeding a small striplight.
I was planning on adding a spur from a (13amp) FCU in the garage, fixing a batten to the concrete fence posts and plastic conduit to this a couple of foot off the ground away from spades etc. I was intending to use 2.5mm T&E (40m length) TLC's voltage drop calculator seems to suggest this is more than adequate.
I dont really see the point of going to the extent of fitting a small CU in the shed for the sake of a light and somewhere to plug my lawnmover/pond pump into once in a blue moon.
I apreciate I could use SWA, but its more expensive and i've got plenty of new T&E spare from a previous job, obvious I'm breaking the law by doing this work myself, but **** happens.
Just looking for any pointers or other suggestions really, does the conduit have to be a specific distance from the ground or is it just common sence?
